Click Here
1970 Cutlass Supreme Tire Sizes
Old Mar 20, 2020 | 01:02 PM
Mauch712's Avatar
Hello,
I have been looking and looking for the right tire size for my 70 cutlass supreme and I have narrowed it down to a Nitto G2 245/45/r18 with an American AR605 Torq Thrust M 18x8 with a 4.5" backspace with a 0 offset for the front and a Nitto G2 255/45/r18 with an American AR605 Torq Thrust M 18x9 with a 5.94" backspace with a 24mm offset. My question to everyone that's able to help me understand tires is if this is a good setup to go with to fill in these fenders on this car and for running stock setup with a disk brake conversion. Want the most rubber on the road without having to rub or roll my lips in the back, the fronts say they would be 26.7" tall by 9.6" wide and the rears would be 27" tall and 10" wide. Any help would be much appreciated.
Thanks,
Mauch712
Old Mar 20, 2020 | 01:38 PM
Those are excellent choices. I think you'll be very happy with the results. Your 255/45-18s are virtually identical in overall size to the 255/60-15s commonly used on these cars.
Old Mar 20, 2020 | 01:47 PM
Mauch712's Avatar
Thanks for replying Joe, I appreciate the feed back!!!
Old Mar 22, 2020 | 03:42 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Those are close to stock height so your speedometer should be close. My 10" wide rims fit with ease, I believe 4.5" back spacing. That leaves an inch between the frame and rim lots of room from the lip as well.
Old Mar 23, 2020 | 07:13 AM
cdrod's Avatar
Rodney
285/40R18 Tire Clearance
Mauch:
70-72 Olds A-bodys have lots of wheel well clearance in the rear. I have 285/40R18s on 18x9 rims with 5.25" backspace: I have about 1-1/2" clearance inside between the tire and frame and about 1-1/4" clearance on the outside between the tire and fender lip. According to the Tire Rack website these tires have a section width of 11.4" and are 27" tall.
Here's some pics from my project.
olds 307 and 403
Wheels and Tires
15
Dec 10, 2017 06:50 AM
Levellord
Wheels and Tires
May 31, 2017 08:52 AM
JRev
Wheels and Tires
15
May 14, 2016 01:36 PM
misterthews
Wheels and Tires
Sep 6, 2011 11:14 AM
jkoester122
Jun 7, 2011 07:25 AM
