Click Here
16" rims?
Old May 11, 2016 | 05:40 PM
Peter Lufrano's Avatar
16" rims?
Hi All,
Anybody out there running 16" wheels on their 2nd gen Cutlasses?
I can't seem to find many wheels available in 16". It seems as though the majority of the wheels are available these days in 15" and then they jump to 17", 18" etc etc.
I'd much prefer to NOT run too low a profile tire on my '71 convertible. I'd like to keep to no lower than a 50 series.
Many thanks in advance!
Old May 11, 2016 | 06:28 PM
csouth's Avatar
I don't know if I've ever seen that size for a GM bolt pattern 5x4.75? Why not 17"? The wheel wells on these cars are big, it still won't look out of place on a car that size.
Old May 11, 2016 | 07:37 PM
Mainly because I don't want to have to use too low an aspect ratio tire.
Most of the www sites list 45 series tires for a 17" rim fitment.
I'd like to run a 245/50 up front and a 265 or so width out back
Old May 11, 2016 | 08:06 PM
csouth's Avatar
Got... You're most likely going to be looking at a Torque Thrust style wheel find the right look, size, backspacing.
Old May 11, 2016 | 08:51 PM
Yeah, I have no problem with torque thrust wheels, but it seems like every other car has them
Old May 12, 2016 | 07:01 AM
Local Hero's Avatar
Yes they are popular. But they won't go out of style after a brief period like most aftermarket wheels do. And they're available in all sorts of widths diameters and backspacings to fit whatever the owner has.
For these reasons I put them on my non-Olds.
Old May 12, 2016 | 07:51 AM
You do realize that the "second gen Cutlasses" are the 64-67 cars, right?
Huh? You DO realize that this is the same bolt pattern as Camaros, right? There are BAZILLIONS of 16" wheels. A ten second search shows 229 16" wheels that fit a 1975 Camaro at this website alone.
Old May 12, 2016 | 09:30 AM
Ooops! my bad. in any case mine is a 1971.....
Joe, does the Chevy Camaro use the same offset etc etc?
when specifying a 16" diameter, the selection is somewhat less......
Old May 12, 2016 | 12:26 PM
droptopron's Avatar
delete
If you are worried about sidewall, a 245/50/17 measures 26.3" in overall diameter. Shorter than the stock tire but close. With the right offset they'll go on np.
A 245/50/16 will obviously be shorter overall & not fill up the wheel well as much.
http://www.tirerack.com/tires/tires....omCompare1=yes
https://www.cokertire.com/tires/styl...te-letter.html
Old May 12, 2016 | 06:02 PM
Thank you for the reply!
Any idea of the correct offset on a 17" wheel to fit the 245/50 tire size?
My car has 2nd gen F body spindles with Hotchkis upper arms and so it sits a little lower than stock up front.
I am considering the Magnum SSI wheels from year one: https://www.yearone.com/Catalog/whee...-magnum-wheels
but their site states the correct fitment is for a 245/45 tire.
Thank you in advance!
grindlecrew
Mar 2, 2013 04:19 PM
CutlassLegend
Care and Appearance
Aug 6, 2011 11:08 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
