Click Here
15x8
Old Mar 4, 2019 | 02:28 AM
kbdecatur's Avatar
15x8
Anyone running 15x8 ss1 wheels on 255/60/15 tires on all 4 corners? If so is ther any rubbing anywhere?
Old Mar 4, 2019 | 05:45 AM
VC455's Avatar
Barely Registered
I have SSII in that size with 275/60 rear and 255/60 front.
There is extensive room in back--nothing comes close.
I have a 1 3/8" anti-sway bar in front and the tire sidewall rubs on it if I go to full steering lock; it makes the inner sidewall shiny where it contacts. The only harm for my application is that the tire white letters are on the inside and are blacked-out. The rubbing tends to wear the black-out off the letters. Otherwise, no other problem on the inside. However, when you are near steering lock and go over a bump, the outside tread catches on the stainless trim around the fender lip and bends it a bit. I have the factory trim piece, which is thicker than the aftermarket trim. I can remove the trim and bend it back. If you have aftermarket trim, there may be permanent damage from this problem.
If I stay mindful in these situations, then I can avoid these problems.
Old Mar 4, 2019 | 06:36 AM
What year and model?
What offset on the wheels?
Old Mar 4, 2019 | 09:28 AM
kbdecatur's Avatar
72 olds cutlass 4.50 backspace.
Old Mar 4, 2019 | 11:20 AM
Check your PM.
Bennyluchiano
Wheels and Tires
Sep 27, 2018 05:41 PM
kbdecatur
Wheels and Tires
Aug 7, 2018 06:31 PM
Patrick Lewis
Wheels and Tires
Jul 30, 2018 01:15 PM
Johnnylindo
Jan 26, 2018 05:12 PM
71POWER
Suspension & Handling
Aug 16, 2013 07:30 PM
