15x10 Weld Alumastar 6" back space?
Is anyone running a 15x10 with a 6 inch backspace on their 68-72 Cutlass?
Just bought a set of 15x10 BS 6" Weld Aluma Stars that I will be running on my 72 Cutlass with a 295/65/15 Mickey ET Drag Radial.
I can always run a 1/4 or 1/2 wheel spacer to offset it to a 5.5" back space if needed.
5.5" bs
If I recall correctly Brian Trick has posted this numerous times on numerous wheel threads.
The only way to have a 15" by 10" rim on 70-72 A body Olds AND have it centered in the wheel house is with a 5.5" backspacing.
Brian can chime in if I am wrong.
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
