Rear window won't lower
Old Jul 21, 2014 | 02:41 PM
Hello group.
The back window on my Vista won't go down. The first time I tried it was with the key in the lock, I got about an eighth of movement then nothing. The switch on the dash does nothing. Battery is charged up. Didn't look at the fuses because I needed a flashlight. If it isn't labeled back window what else would it be tied in with?
Is there a secret to getting the window to work when it doesn't want to? Or, what's a good way to disassemble the tailgate from the inside? I don't want to start ripping and tearing only to find out I've broken some hidden and very expensive piece.
Thanks everyone.
Old Jul 21, 2014 | 06:18 PM
You can take apart the door from inside in fact it is in the service manual how to do it. Then you can take the motor out and push the window down. I did it on a parts carw/ no wiring. it worked.
Old Jul 22, 2014 | 02:59 PM
Thanks Greg. I don't have the service manual and I couldn't find it on Wild About Cars. But it shouldn't be that hard to figure out, so I'll give it a go.
The 1/8 I got it to move that once, was that the last hurrah for a motor gone bad? I'd venture to say the window hasn't been messed with in 10 years.
Old Jul 22, 2014 | 04:34 PM
starfire's Avatar
Here's the link to the FB manual:
http://wildaboutcarsonline.com/membe..._SM_Sect_9.pdf
It should work if you log in, maybe not, I'm not sure how they do it, but if not the section of the FB manual you want is spelled out in the link.
Old Jul 22, 2014 | 04:57 PM
Excellent Alan thanks. That's exactly what I wanted.
wyteon
Vista Cruiser & Wagons
Nov 30, 2018 11:33 AM
stevengerard
Sep 10, 2014 03:17 PM
crank shaft
Feb 11, 2014 05:00 PM
oldspackrat
Jan 20, 2014 05:17 PM
Ablast
May 18, 2012 05:40 PM
