Rear Window Rollers
Rear Window Rollers
I'm fixing the rear window on my 68 Cutlass Cruiser and it's going to need new rollers for the regulator. Does anyone know of any that fit the back window on the wagons?
I did notice there was a Dorman 74444 roller laying on the floor and while it does slide in the track, the ID is definitely too small for the stock rivets. If there's an off the shelf roller and stud available that would be great, otherwise I need to cobble something up using a roller that fits and some miscellaneous hardware.
I wonder if those are the same as the 74444 rollers, since they're listed as compatible for late 70s Vista Cruisers.
Either way I picked up another 74444 roller and some generic 1/4-20 hardware from the store. Drill out the old rivets, countersink the rollers, and that will do the trick.
I will say for these old wagons, with the way there's no replacement parts available you really have to get creative.
Quarter Window Roller Assembly: For 1968-72 Cutlass Holiday Coupes
and Convertible rear Quarter Window Rollers. Includes metal body with
plastic and rubber bushings. Attaches to glass and regulator assembly on
the quarter windows only. Two used per car.
QWR682 Quarter Window Roller Assembly
1968-72 Cutlass-442 Holiday Coupe & Conv. 11.50 ea.
Window Guide Roller
WOW. I was going to ask the very same question.
I, too, have to replace those rollers. Are you saying that the Doorman 74444 roller doesn't work?
All that's left of my driver's side roller is a plastic ring. I ordered two of the Doorman rollers because I thought they'd just slip or snap onto the stud of the regulator. Is that not the case? The parts catalogs say that those rollers are good from 1973 and up.
I reckon I"ll pick up the rollers myself today and find out.
An interesting observation about the 'flat top' version of the Vista Cruiser. I did look up when the term "Cutlass Cruiser" came into being - 1971. It was the popular term for 1972 flat top station wagon too.
In and after 1973, the term Vista Cruiser was loosely used to describe the non vista intermediate Colonnade style wagons (which were in reality flat top station wagons), and the 'Cutlass Cruiser' faded into oblivion.
I didn't want to drill out anything from the original regulator though, so I took another approach.
I brought the Doorman rollers home and quickly discovered that they won't simply "slip onto the stud". They could if it weren't for the flange at the end of the stud. I then inspected the passenger side track and found that it is also just a simple roller, but it is intact.
I'm a little proficient with a dremmel tool, so what I did was cut the plastic collar from the button of the new roller off and with a cutter, expanded the internal diameter of the new roller so that it was slightly smaller on the stud side than the outer "track side" so that the factory stud will kind of just... "snap" into the new roller. I used a heat gun to soften up the plastic to make this a little easier.
I don't know how to better explain that, and I wish I had taken pics, but... I didn't know IF it would work, and to be honest, I don't know how long it will work for. Plus, I was covered in grease anyway. But when I put it all back together, greased up everything, it rolled smooth as silk dozens and dozens of times as I manually pushed and pulled the glass up and down while drinking a beer, so....
And then, of course, something else broke on the window motor gear, but that's another matter.
If this roller doesn't work, I"ll have to come up with something else, but honestly, in the past 4 months, I've gotten into that tailgate for one thing or another so many times that I'm kind of a pro at it now.
OP is correct in that you have to get creative.
CrazedCountryRebel
Jan 12, 2011 09:06 AM
