Am I rememberring correctly?
Old November 11th, 2008, 10:31 PM
Toronado's Avatar
A freind had a fully loaded '72 Vista Cruiser with pwr windows, etc. and a 455. I would bet money the A/C compressor had twin fan belts to it. So, I wonder why the '72 Toronado 455 A/C compressor has one belt? Does anybody here have a '72 455 with twin belts on the compressor?
Toronado is offline
Old November 13th, 2008, 02:24 PM
Registered
Bluevista's Avatar
I looked in my GM parts catalog pulleys and belts section and it doesn't show show dual belts for AC compressors on the Toronado or Vista Cruiser/Cutlass in '72.
Actually I didnt see any dual belt compressors for any Oldsmobile, from '70-'75 at least.
Allan
Bluevista is offline
Old November 13th, 2008, 02:28 PM
The dual and triple pulleys I found were for the water pump.
Allan R is offline
Old November 13th, 2008, 06:42 PM
The pulley is integral to the compressor clutch. I have not seen one with dual belts. I think you're confusing it with the alternator or PS pump.
joe_padavano is offline
Old November 14th, 2008, 04:49 AM
Didn't the later cars have a dual pulley on the AC compressor so they could run an additional belt for the smog pump? I thought that was in the late 70s though...
Olds64 is online now
Old November 14th, 2008, 11:26 AM
Lady72nRob71's Avatar
With the amount of torque needed to drive the A6 compressor, two belts should have been standard on all models to reduce belt stretching.
I have noticed that if the A/C belt is not gorilla-tight, the bottom of the belt flaps a lot and was actually cutting through the lower radiator hose.
My '86 has a similar problem, but not as bad. Of course it has the R4 compressor...
The cheesy cogged belts stretch even more, making the problem worse.
Anyone know where i can get a non-cogged variety? All the big local chain stores only carry the cogged ones for 1972...
Lady72nRob71 is offline
ent72olds
March 16th, 2014 07:57 PM
oldzy
Suspension & Handling
January 25th, 2011 09:07 PM
oldzy
Drivetrain/Differentials
October 31st, 2010 08:23 PM
w-30dreamin
June 17th, 2010 08:03 AM
GothamCity
March 22nd, 2010 12:08 PM
Quick Reply: Am I rememberring correctly?
