46-48 Convertible owners and others, What are these?
I need a little help identifying the proper names and a source for these small parts on the inside of my 47 convertible door. One is clearly a roller and I can get from Fusick or Steele Rubber. The other two (see thumbnails) are a mystery and I don't know if all 46-48 cars had them or just convertibles.
It looks to me like some kind of rubber donut must have gone around them and helped hold the window steady along with the roller. My drivers door has none of these so I will not only need cushions/bumpers but the steel part that holds them. Thanks for furthering my continuing education.
Jerry
Jerry
Maybe convertible only
Pat, I'm thinking it may be on convertibles only. I talked to Chevs of the 40s today because the small Olds and Chevy convertibles have some interchangeable parts. Counterman had the very same rollers and rubber stops as Fusick lists. But does not show parts availability for the mounts that hold those rubber rollers and stops. Fortunately the mounts are pretty simple sheet metal stamped as you can see from the photos. I think I can fabricate them.
Jerry
RetroRanger
Feb 25, 2014 05:04 PM
evans_78
Mar 20, 2013 12:46 PM
alwayscode390
Nov 10, 2011 09:35 AM
Aussie67Delta88Custom
Feb 14, 2008 04:49 AM
