56 Fuel gauge problems
My 56 fuel gauge does not seem to function properly. When I put 12V plus on the left contact seen from above from the face side and I am grounding the right contact, the fuel meter should go to full.
The hand only moves a tiny little bid, however. I tried it directly on the battery, 11,8 volts to the left side and the right side on minus.
I measured the resistance and came up with 90 ohms. When I put 12 volts on the left contact and put the voltmeter on the right one, connected to ground, I only get a few volts.
Can you help me explaining, what I could to to make it function? Do you happen to have a 56 fuel meter for me or an entire speedometer cluster with fuel meter in there?
thanks
brgds
The_German
thanks
brgds
The_German
I believe the case of the gauge is supposed to be grounded also. If no wire is connected from the sender then the needle should go past full. If the terminal for sender is connected to ground then it will go to E. Are you sure your gauge and sender are for a 90ohm system?
Eric, I will see, what I can find out. First of all, I will clean the mechanics, some alcohol, a little oil etc.
Then I will test it again.
At the same time, I will see, if I can find a another fuel gauge at ebay or so, then I have enough to experiment and find the problem....
I have no clue, if this is supposed to be a 90 ohm system, all I know is that the gauge is an original gauge for a 56 and I can read my ohm- meter saying it it 90 ohms.
Honestly, I do not know what is right and wrong here....
I'd bet that in 99.9% of all cases, it's the sender or a bad tank ground that's the culprit, and not the gauge. I've had the tank out of four different cars in the last year. The sender was always at fault. I know it's a PIA, but you're going to have to drop the tank, and pull out the sender. The good news is that Fusick has the sender for your car. I put one in my '55 last year.
Great news,there's a first for everything. Thanks for reporting back. We like pictures , when you get time. There's a post here named "54-56 Owners Unite" has most all of the '54-'56 owners and picture of their car,you might like to look at. Larry
JPMDaddy
January 31st, 2020 04:01 AM
