58 super 88 headlight switch and windscreen wiper switch removal
Old Aug 30, 2013 | 03:53 AM
gwunta's Avatar
Hi all, does anyone know how to remove the above items? I have stripped the dash completely but the above are stopping further progress. I have removed the wipersand wiper actuator and disconnected the cable at the actuator end. The headlight switch has me beat. Any help would be very much appreciated
Old Aug 30, 2013 | 06:46 AM
There is a spring loaded button on the side of the switch behind the dash. Push it in and the **** and shaft will slide out. Then you can remove the nut, and drop it down.
Old Jun 21, 2024 | 05:03 PM
Red 70 Cutlass's Avatar
I am replacing the headlight switch on my 70 Cutlass and I push the spring in with the light switch at the off (in) position but the shaft won't come out. Worst case might be to break the **** off the shaft and remove the switch, requires buying a new shaft/****. Any thoughts?
Old Jun 21, 2024 | 05:36 PM
You have to pull the **** to the headlights on position, push the button, and the pull the ****/shaft out. Best to do with the battery disconnected.
Old Jun 22, 2024 | 08:59 AM
Thanks oldcutlass for your help. I just finished installing the new headlight switch and it works perfectly !!!
justacog
Feb 4, 2024 06:36 PM
Christophe2m6
Oct 22, 2014 02:40 PM
wisniows
Jan 27, 2014 06:45 PM
medri
Apr 29, 2012 05:33 PM
69-Sguy
Mar 3, 2007 01:30 PM
