56 Super 88 Conv: Where is the conv top pump?
Old Aug 27, 2011 | 01:16 PM
The_German's Avatar
Strange story:
Sometimes the switch causes reaction in the conv top hydraulics, sometimes it does not.
There is power on the switch and the switch puts the power on the up, resp down cable, but no reaction.
I need to know how to get to the pump to see if the power arrives there.
Strangely enough, there is no wiring diagram in the shop manual, no clue, why that is the case.
Can you help?
The_German
Old Aug 27, 2011 | 03:41 PM
hialeah56's Avatar
1956 holiday coupe
do you have this book? I wonder if it would help, I think these show operation and service
btw there's two to choose from right now on ebay
http://www.ebay.com/itm/1956-Oldsmob...item5642dfa09b
http://www.ebay.com/itm/1956-OLDSMOBILE-CONVERTIBLE-TOP-MANUAL-BROCHURE-ORIG-/170587100639?pt=LH_DefaultDomain_0&hash=item27b7c8 95df
Old Aug 27, 2011 | 06:45 PM
56oldssuper88's Avatar
youngin'
maybe a short or a bad switch?
Old Aug 28, 2011 | 08:12 AM
The_German's Avatar
Hialeah, I have that book, but I need more, I need the wiring diagram for the roof and also the location of the relay switches and the electrical connections at the pump.
From the trunk side I see some tubes etc, but no cables etc.. Where is all that stuff??
Old Aug 28, 2011 | 08:16 AM
Tedd Thompson's Avatar
Top pump
Behind the back seat, under the boot that holds the top when its down is a aluminum box which holds your motor and pump.This may be reachable from the trunk( I can't remember for shur it's been awhile) once there you can check the motor from that location. Hope that helps... Tedd
Old Aug 28, 2011 | 08:18 AM
The_German's Avatar
Tedd, there is something like a bottle visible, but no wires. I will rush out to the garage now and see, if I can find it!! Thanks so much!
66olds98conv
Ninety-Eight
Mar 21, 2013 12:52 PM
valmaye
Feb 19, 2012 10:41 AM
LoganT5262
Oct 17, 2010 06:59 AM
aholiday
Jan 11, 2010 05:57 AM
