Timing adjustment
Timing adjustment
Hey all, been trying to figure out reasons why my trans won’t shift up on my 55 olds super 88. Where I live the timing should be set at 14 degrees but I just realized it may only be at 7 degrees, could that be the reason my car won’t go out of first gear?
Ok. When I checked the timing I did it by myself so I turned the crank while having a screw driver sticking out of number 1 cylinder until it got to the highest point then had to make a mark on the balancer but also the rotor was point the opposite direction than #1 cylinder so I rotated it all the way around again and according to my mark it was at 14 degrees, the only way it stays on is because I have the idle screw all the way in. Is it possible I was on exhaust highest point and not compression?
Yes, you may have been on exhaust. Remove 12V from the distributor and have a friend kick over the starter while you hold a finger over the #1 spark plug hole. Your finger will blow off when the piston moves up for compression. Just bring the piston up to TDC and mark your harmonic balancer.
But back to the issue, the ignition timing setting would not have an impact on the transmission shift point.
Understand, it would definitely have to be dependent on geographical "altitude". Yea, agree on timing should have no influence on trans shift point (that I'm aware of anyways?).
There should be a 1/4 in notch in the rim of the balancer.
The right side of the notch is TDC. The left side of the notch is 5 degrees before TDC.
The factory setting was 5 degrees. As others mentioned, this setting is subject to revision today.
There will be a spiked pointer sticking out of the timing chain cover.
Check your timing with a timing light at idle, with the vacuum advance line disconnected and plugged.
As others have mentioned, ignition timing has nothing to do with transmission shift points.
Using a screwdriver in the spark plug hole might get you 10 degrees either way of true TDC. Not accurate at all.
I never heard of this timing being so high either until I started working at this hot rod shop and they are the ones who explained the 14 degree timing to me, other than that yes I had thought it was 5 or 6 degrees according to how the factory made it. And yes I believe my issue is throttle valve too or bad trans which I’m not convinced of yet
ok all great info to know which I did not do thank you. However I’m not sure if someone over the years replaced the bottom pulley or what but mine has no marks of any kind, I have looked for that notch before and it’s not there but I’ve seen in it on a different motor same 324 so I know what it looks like and mine looks different from that so I’m stumped
Get a vacuum gauge and hook it up to manifold vacuum.
Start the engine, and turn the distributor one way or the other until you get the highest vacuum reading.
Clamp the distributor down, and test drive it.
If it doesn't "ping" under load, you're good.
If it does ping, back off on the timing a little bit.
