I am coming up with 1/2" x 3.25" x 7", but they are still on the car. The 3.25" inside diameter measurement is the most unknown one, I can tell they are 1/2 diameter bolts.
Thanks for any help.
Sorry, I can't come up with a micrometer that opens wide enough. But using a tape measure it looks like your 3.25 is correct. I'd be willing to send you a used one or the metal plate if you cover the shipping costs. Then you could have a loose one to measure. John
I'm not sure what your time frame is for this but some point this winter i will be having some made at Plattsburgh spring for my 55 as Flemming442 had suggested, i live about 20 minutes from there.
I would happily ship them if you can wait a few weeks.
Yes, I did measure the axle tube, it's 3.25, so there you have it. Thanks everyone, decided to go with General Spring in Kansas. Each U Bolt with washers and nuts - 10 bucks.
