Rear Leaf Spring - U Bolt Size 1951-56
Old Nov 26, 2023 | 07:38 AM
madmax442.com's Avatar
madmax442.com
I am coming up with 1/2" x 3.25" x 7", but they are still on the car. The 3.25" inside diameter measurement is the most unknown one, I can tell they are 1/2 diameter bolts.
Thanks for any help.
File Type: png
Old Nov 26, 2023 | 09:31 AM
fleming442's Avatar
Once you determine what you need, Plattsburgh Spring in New York is very reasonable for custom made u-bolts
Old Nov 26, 2023 | 03:48 PM
2blu442's Avatar
Sorry, I can't come up with a micrometer that opens wide enough. But using a tape measure it looks like your 3.25 is correct. I'd be willing to send you a used one or the metal plate if you cover the shipping costs. Then you could have a loose one to measure. John
Old Nov 26, 2023 | 05:16 PM
OLDSter Ralph's Avatar
Measure the diameter of the axle tube near U-bolts.
Old Nov 27, 2023 | 07:02 AM
ub2693v's Avatar
I'm not sure what your time frame is for this but some point this winter i will be having some made at Plattsburgh spring for my 55 as Flemming442 had suggested, i live about 20 minutes from there.
I would happily ship them if you can wait a few weeks.
Fusick also has them available on their website.
Old Nov 27, 2023 | 09:24 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I would just buy the ones John has.
Old Nov 27, 2023 | 12:17 PM
madmax442.com
Yes, I did measure the axle tube, it's 3.25, so there you have it. Thanks everyone, decided to go with General Spring in Kansas. Each U Bolt with washers and nuts - 10 bucks.
Old Dec 6, 2023 | 09:58 AM
madmax442.com
Once I got the old U Bolts side by side, 7" length is about a 1/2" short. I made it work with 7" length, but the real size is: 1/2" x 3.25" x 7.5" .
Mlunsford33
Wheels and Tires
Oct 18, 2020 04:24 PM
servexcell
Suspension & Handling
Sep 28, 2017 06:52 AM
sammy
Sep 23, 2013 05:38 AM
Joffroi
Brakes/Hydraulic Systems
Jan 17, 2011 02:02 PM
72CUTTY
Jan 20, 2009 08:00 PM
