Lifters
Old Sep 10, 2023 | 10:14 AM
Rickey1964's Avatar
Lifters
What is the best set of Lifters to replace the original set in my 1955 Starfire with the 324 engine?
Old Sep 11, 2023 | 03:30 AM
mpolds's Avatar
I have exactly one set of *** O.E.M. *** G.M. *** Valve Lifters in the G M boxes…
It certainly doesn’t get better than that !!!!!
Always best to simply call me —- 516 - 485 - 193five —— Craig….
Old Sep 11, 2023 | 03:59 AM
BillK's Avatar
Why are you replacing the lifters ? Its a giant crapshoot putting new lifters on an old camshaft.
Old Sep 27, 2023 | 01:18 PM
Rickey1964's Avatar
Well, I went through with changing the lifters. It turned out the lifters were not original, but a replacement set that are 350 Chevy. I bought and my Dad installed the new (and correct) lifters as we already was getting a valve job done, and that problem appears to be solved.
Old Sep 27, 2023 | 05:37 PM
Rickey1964's Avatar
Craig, I got these lifters before I saw your message.
Old Sep 27, 2023 | 09:16 PM
Tedd Thompson's Avatar
I assume, you are running on a new cam with those new lifters, otherwise the wear pattern will not match and lifters and cam will not last any time at all.... Tedd
Old Sep 28, 2023 | 03:43 AM
Rickey1964's Avatar
Tedd, the cam was inspected by my father, then by my brother. Both said the cam did not need to be changed in this instance. I was going to buy one if they had said it was needed. I have to do what they say because they know what they are doing.
young olds
Nov 23, 2021 06:10 AM
RandyS
Nov 4, 2021 07:58 PM
grannys442
Jul 8, 2021 08:26 AM
JIM'S w30
Jul 1, 2019 08:14 AM
56 BULB
Dec 8, 2018 02:54 PM
