1954 glass fuel bowl removal
Old Sep 24, 2021 | 01:54 PM
oppeds's Avatar
I want to remove and clean old fuel in the glass fuel bowl - If I loosen the bail nut and swing it away should the bowl come off?
I did loosen the bail nut and swing it away but the bowl did not easily come off, I did not want to force it so I thought I'd ask experts here.
Old Sep 24, 2021 | 02:08 PM
Everything is probably stuck to the gasket, may need some gentle persuasion.
Old Sep 24, 2021 | 02:41 PM
If I'm not mistaken the fuel bowl you're referring to is a sediment bowl I believe, correct? Yes, if you loosen the bail nut & swing the arm away from the bowl, the sediment bowl should fall into your hand. As Eric suggested, it needs some persuasion from a rubber hammer lightly tapping around the sides of the bowl, or a large pair of channel locks with a towel wrapped around the sediment bowl should work. Perhaps the last case scenario would be a very small screwdriver gently rocking the sediment bowl between the glass and the metal surrounding lip might work.
Old Sep 24, 2021 | 02:53 PM
oppeds's Avatar
Thanks Eric and Norm - I will try to "persuade" it off and let you guys know how I make out.
Old Sep 24, 2021 | 03:00 PM
Depending on the exact type of glass bowl you have (whether it's the OEM glass bowl or a replacement glass bowl) - it might even be an entire replacement sediment fuel bowl assembly someone else may have replaced, sediment glass fuel bowls and the gaskets are pretty much easily procured. Many auto manufacturers used basically the same glass fuel bowl during that era. The absolute worse case scenario is you end up purchasing a new sediment fuel bowl assembly and plumbing it into your current fuel lines. Good luck with the removal.
NerdInATie
Nov 14, 2020 04:08 PM
Scut
Sep 6, 2018 07:27 PM
70-442-W30
May 17, 2016 09:10 AM
1962oldsguy
Jan 7, 2014 05:10 PM
aliensatemybuick
Nov 12, 2009 03:11 PM
