Need help identifying hood lip trim, 1954 and 55?
Old Mar 6, 2021 | 01:21 PM
2blu442's Avatar
Hi All
While going through the clutter looking for something else I came across these two pieces of trim. I believe the wider one is from a 1955 hood, but am not sure about the narrower one. I'd guess 1954 since those are the two years of parts cars I've had. But don't remember for sure where I got it, so that might not be correct. For those of you who know this vintage please let me know your thoughts. I've taken several photos of each, if you need a photo or measurement not here let me know. Here's the two side by side.
John
Old Mar 6, 2021 | 01:22 PM
2blu442's Avatar
Then here's what I think is from a 1955
Old Mar 6, 2021 | 01:24 PM
2blu442's Avatar
And the one I'm guessing is 1954
Old Mar 6, 2021 | 02:09 PM
redoldsman's Avatar
Proud Viet Nam Veteran
John I believe the narrower one is a 54. I just went out and looked at my car and it looks just like that one and the measurements are the same. I am not sure about the other one. Maybe Tedd will speak up since he has a 55.
Old Mar 6, 2021 | 02:32 PM
2blu442's Avatar
Thank you Glenn!
Old Mar 6, 2021 | 04:53 PM
Loaded68W34's Avatar
I am not sure what the trim is from, but it looks like you are using a 68 or 69 Toro as a background for your photos. Do you happen to have a bumper jack box (cardboard sleeve with Styrofoam insert) for one? Should be the same 68-70. Possibly 67 also.
Old Mar 6, 2021 | 05:40 PM
2blu442's Avatar
Not sure, I haven't got the trunk opened on this car yet. I drug it home for parts, the nose had burned when a forest fire got too close. I will keep you in mind when I get it open and see what's there.
John
Old Mar 6, 2021 | 06:27 PM
Thanks. Is the car a 68 or 69?
Old Mar 6, 2021 | 06:35 PM
Tedd Thompson's Avatar
The measurements for the big one seem t be the same as my 55- 41 1/4 and I get 3inches from the top of the chrome to the first bend. hope that helps
If that chrome lip is as good as it looks it's worth quit a bit for someone who needs one. In the road salt areas those things rot out quite regularly and they are hard to find.... Tedd
Old Mar 6, 2021 | 06:43 PM
2blu442's Avatar
Originally Posted by loaded68w34
thanks. Is the car a 68 or 69?
1968
Old Mar 6, 2021 | 06:44 PM
2blu442's Avatar
Thank you Tedd! Yes, both of these pieces have minor rust, some damage to repair, but solid pieces.
CarWizard
Jan 22, 2021 02:32 PM
Alan1962
Aug 23, 2020 06:07 PM
spgosselin
Jun 6, 2020 05:39 PM
54olds98owner
May 16, 2020 05:16 PM
sevntyW30auto
Dec 26, 2018 03:32 PM
