convertible switch modification
Old Dec 23, 2020 | 06:30 PM
maineolds's Avatar
I'm having so much fun restoring my 1949 Olds 88 convertible. I had to share this simple modification with all of you!
A previous owner converted the hydraulic top to run off an electric motor. They used a DPDT (double pole double throw) toggle switch with 6 posts to power the top up and down. Using this kind of switch allows you to reverse the motors polarity causing the same motor to work in both directions needed to put the top up and down. That's great! But what I didn't like was the fact that a "new" toggle switch had to be used under the dash, land that it left the factory push/pull "top" switch that was intended to be connected to the hydraulic controller useless.
I wanted to be able to power the top using the old control switch. But how? Well, the solution seems crazy, but it works fantastic! Here's a video:
Old Dec 23, 2020 | 07:32 PM
Tedd Thompson's Avatar
Good work and there won't be any modern looking switch to look at..... Tedd
Old Dec 23, 2020 | 07:52 PM
maineolds's Avatar
Thanks! It sure would have been easier to simply attach the “top” **** to s push/pull type switch, but no one makes a DPDT push/pull. That’s the key. You’ve got to be able to reverse polarity.
Old Dec 23, 2020 | 08:28 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Nice job. Somebody did a lot of work converting the top to an electric motor.
Old Dec 24, 2020 | 07:51 AM
rocketraider's Avatar
Oldsdruid
Genius. I like. Just make sure the switch is capable of carrying the amps that top motor pulls.
LJ72Cut
Apr 21, 2018 09:57 AM
CuttyShark
Oct 31, 2016 08:14 PM
coppertopgmc
Jun 19, 2015 07:13 PM
kbdecatur
May 3, 2012 01:12 PM
JCervantes
Oct 29, 2008 08:12 PM
