A bit of shimmy
Old Dec 27, 2020 | 07:00 PM
maineolds's Avatar
A bit of shimmy
While driving my 49 Olds 88 I get a bit of shake through the steering shaft and wheel around 40mph that smooths out at higher speeds. The tires are newer coaker tires and look to be professionally balanced. I have no reason to think they aren’t balance or to think they have lost a weight.
my king pins have a bit of play, but I’m not sure how much is to much. Think I should start with a clean slate and replace the kingpins? Whew bearings are greased and properly adjusted. My steering box was in real bad shape when I got it. Super hard to turn. I discovered it was bone dry. I added the proper steering box lube and it helped free up the box.
Old Dec 27, 2020 | 07:46 PM
I would start with the inexpensive first and get the tires balanced.
Old Dec 27, 2020 | 08:32 PM
I agree, this seems to indicate a balance issue.
Old Dec 28, 2020 | 08:13 AM
Tedd Thompson's Avatar
X3 on the balancing and not all Coker tires are created equal some will give fits trying to balance them... Tedd
Old Dec 28, 2020 | 02:41 PM
Sugar Bear's Avatar
Check In your area for Hunter Road Force balancing. Also ask if they will check the current balance as a reference point but still get the Road Force balancing. Tell the tech doing the balance the symptom, they may spot something.
Good luck!!!
Old Dec 28, 2020 | 02:48 PM
maineolds's Avatar
Thanks everyone. I’ll keep posted
donfitzgerald
Suspension & Handling
Apr 6, 2016 08:20 AM
Oldsragger
Mar 15, 2015 05:22 PM
mzbk2l
Mar 6, 2014 08:35 AM
Jetstar 88
Jan 31, 2012 03:29 PM
MJAKS462
Aug 17, 2010 03:19 AM
