Guidance to mate 1957/1958 371 engine to 1955 hydromatic
Old Oct 20, 2020 | 09:10 PM
Love1955oldsmobile's Avatar
I need guidance to mate 1957/1958 371 engine with manual transmission to 1955 hydromatic. Generally speaking i have lots of 1954/1955 engine and transmission parts but limited 371 engine parts. Thanks. Ron
Old Oct 20, 2020 | 09:57 PM
Charlie Jones's Avatar
Phantom Phixer
Since you have a crank with a pilot bushing already , this is a simple " bolt in " swap .
'55 flywheel should bolt right up to the crank .
Bellhousing will bolt right up to block .
The only problem you will run into will be a severe imbalance in the engine .
The '57 and up engines are " offset balanced " , where the flywheel is purposely weighted on one side to make up for a lack of counterweighting in the crank .
A balance weight must be added to the '55 flywheel so it matches the imbalance of the '57 flywheel .
Aedwards
Ninety-Eight
Nov 25, 2014 01:01 PM
Rowdies
Apr 11, 2012 09:23 PM
nbfalj
Apr 8, 2012 09:29 PM
Hal Robinson
Tech Editor's Desk
Jan 26, 2010 10:32 AM
Kennybill
Feb 11, 2009 12:34 PM
