56 Olds 2bbl to 4 bbl swap
Old March 24th, 2019, 12:41 PM
CA56olds88's Avatar
hey guys-
wondering is anyone has swapped intakes on a 56? So far I have a stock 4 bbl intake and carb out of a 56, gaskets, vac & fuel lines, and carb spacer.
Questions:
1. Is the valley pan the same on both?
2. Will carb linkage match up?
CA56olds88 is offline
Old March 25th, 2019, 06:17 AM
Ozzie's Avatar
Originally Posted by CA56olds88
hey guys-
Questions:
The valley pan (a.k.a. cylinder block top cover) should be the same. The parts book says some of the linkage is different between 2bbl & 4bbl. I got mine from the same donor car as the manifold. 7007221 should be your carb model for the auto trans.
Ozzie is offline
56oldssuper88
May 31st, 2021 07:45 AM
Brian5688
February 8th, 2018 09:10 PM
Chris289
July 23rd, 2015 02:58 PM
56rocket
May 2nd, 2012 04:47 AM
ShaunM
October 16th, 2011 12:38 PM
Quick Reply: 56 Olds 2bbl to 4 bbl swap
