257 inline eight starter
Old January 9th, 2017, 10:24 AM
Ornberg's Avatar
Did anyone know if there's any aftermarket high torque mini starters for Olds straight eight? I have problems with the startermotor after convert my -40 to 12 volt. The starter overrun and have problem to engage the flywheel. It feels like the starter run too fast now with 12 volt. I never had this problem before with 6 volt. Anyone have any solution on my problem?
Thanks.
Ornberg is offline
Old January 9th, 2017, 06:03 PM
stellar's Avatar
Can you give me the original starter number? It will help me find a solution.
stellar is offline
Old January 9th, 2017, 06:15 PM
classicmuscle442's Avatar
Have heard of using 8 volts instead of 12, just a thought.
classicmuscle442 is offline
Old January 10th, 2017, 04:56 AM
stellar's Avatar
Replace the 6 volt fields with 12 volt fields or there is a company in california that makes 12 volt starters to replace 6 volt, but they can be a bit pricey and I am not sure if they make one for your application.
stellar is offline
Old January 10th, 2017, 10:53 AM
Ornberg's Avatar
The starter is still in the car and theres no way I can see the number tag right now. I will get the starter out in a couple of days. The starter is the type without solenoid, its a pedal starter. I had it apart a few weeks ago and all look good inside no dirt just clean. The Bendix gear look good and the teeth on the gear shows no damage and the flywheel looks fine too. Here's a photo of the starter mounted to the engine.
I was hoping to find a modern 12 volt mini starter who will fit right in but maybe I'm a little too optimistic... I will ask around over here in Sweden if there are any company's who can replace the field winding.
Ornberg is offline
Old January 10th, 2017, 11:01 AM
Ornberg's Avatar
Cris, do you mean 8 volts just for the starter? If so how can I achieve that? Someone suggested to run two 6-volt batteries connected in series and use one of them for the starter but there's no space for them in the engine compartment.
Ornberg is offline
Old January 10th, 2017, 11:31 AM
stellar's Avatar
There is probably a modern 12 , but it will have a solenoid on it and you will need a starter button. 12 volt fields may be available for that starter if you have a shop over there to install them.
stellar is offline
Old January 10th, 2017, 12:22 PM
Ornberg's Avatar
Do you know where I can find a modern 12 volt solenoid starter? I would gladly avoid the starting pedal in favor of a start button.
Ornberg is offline
Old January 10th, 2017, 01:39 PM
stellar's Avatar
I contacted the company, but they do not ship to Sweden. Without the original starter number they can not tell me if they have made a replacement for your starter. Get me the number and I will see what I can find out. I will also look into what fields are needed to convert your 6v to 12v. Than you can choose how you want to go forward.
stellar is offline
Old January 10th, 2017, 03:37 PM
You can run a six volt system with eight volt battery, just one battery.
Old January 10th, 2017, 08:36 PM
Ornberg's Avatar
Thanks for your help, I really appreciate it. I will get back to you with the starter number asap.
Ornberg is offline
Old January 10th, 2017, 08:42 PM
Ornberg's Avatar
My -40 is modified with air ride suspension so I need 12 volts for the solenoid valves. That's why I convert it to 12 volt in the first place but thanks for your input.
Ornberg is offline
Old January 10th, 2017, 10:19 PM
Andreas.Johansson's Avatar
Hi Ornberg
Good to see some more swedes around J
On a conversion, I did some years back Iused an old-style battery with lead plates between the cells, each cell have 2Vand just attach a separate cable only for the starter.
I went 8V on mine and it worked out finefor a couple of years until I sold the car.
All the way down in the Picture you will see the starter Cable.
Andreas.Johansson is offline
Old January 11th, 2017, 10:52 AM
Ornberg's Avatar
Originally Posted by Andreas.Johansson
Hi Ornberg
Hi Andreas, yes likewise!
Looks like a Hudson Twin H-Power engine.... nice! Your conversion looks good and that's one nice way to solve the problem. A friend came up with another solution for my problem and I will give it a shoot. I will be back with pics if it turns out good.
Ornberg is offline
Old January 11th, 2017, 12:40 PM
Didn't the old MG's and other older euro cars use a small 6v battery so you can hook 2 in series.
oldcutlass is offline
Old January 11th, 2017, 03:00 PM
That's beautiful.
Old January 11th, 2017, 03:02 PM
Hi Ornberg
Great idea, have never seen that type of battery.
Old January 12th, 2017, 09:43 AM
Tedd Thompson's Avatar
This would be a farmer fix but if you used a smaller diameter battery cable (especially if you are using a 6V 1/0 cable now) you will get a voltage drop. This maybe enough to slow things down enough to get your engagement. Cheap also.... Tedd
Tedd Thompson is online now
Old January 13th, 2017, 07:18 AM
Ornberg's Avatar
Ok so this is the solution I came up with: this will be photo heavy...
The problem in the first place was that the starter run way too fast when convert to 12 volt and the Bendix gear have trouble to engage the flywheel. At least in the teori. A friend come with the idea to decrease the distance the Bendix gear have to travel before smash in to the flyweel. The longer distance the more speed as the gear pick up speed on its way forward. First, I measured the distance from the starters mounting spot to the outside flange on the flywheel. Sorry for all measurement in mm, we use the metric system over here.
25.3 mm
18.9 mm from the flange to the front of the gear. So the distance the gear have to travel before reaching the flywheel are around 6 mm. )25.3 - 18.9 = 6.4 mm
I will make a distance ring with the thickness of 4.5 mm and place where the red arrow show.
Some work with the Lathe.
The 4.5 mm distance ring in place.
Now the gear sits closer in the normal position and the travel to reach the flywheel is only around 2 mm so the pick up speed will be slower.
This arm must either be bend to compensate for the forward moved Bendix gear or as I did, weld a small steelplate to the arm as in the last pics.
This modification works like a charm. I hope other can have interest in this solution if facing the same problem. Thanks
/Per Ornberg
Ornberg is offline
Old January 13th, 2017, 08:11 AM
I found this fix unique and interesting. I'll store this information somewhere in the back of my brain and if I live long enough maybe I can pass it along to someone else down the road.Good work... Tedd
Old January 13th, 2017, 08:57 AM
stellar's Avatar
Super idea. Engagement problem solved and still a fast crank. Still curious as to the number on the starter. Did you get it by any chance?
stellar is offline
Old January 13th, 2017, 09:31 AM
Ornberg's Avatar
Thanks Tedd
Ornberg is offline
Old January 13th, 2017, 09:33 AM
Ornberg's Avatar
Yes, here's the number. Delco model 1107907 OA-4
If you found anything please let me know. Could be good to have one in reserve.
Thanks.
Ornberg is offline
Old January 14th, 2017, 06:07 AM
Rocketowner's Avatar
Smile
Congratulations on creating a "Fix" for your problem. Sometimes ,on these old cars you need to be very creative and determined to figure out problems. I'd rather have one person with determination
and the ability to be creative, than two engineers. Larry
Rocketowner is offline
Old January 14th, 2017, 07:27 AM
Ornberg's Avatar
Thanks Larry
Ornberg is offline
Old January 14th, 2017, 07:34 AM
Ornberg's Avatar
Another quick question, is there any difference on later 257 flywheel? (1941-1948). If not the starter should work on all year straight 8, but maybe the Hydramatic equipped cars will be different. And will a starter from a 239 six be the same?
Ornberg is offline
Old January 14th, 2017, 08:45 AM
Ozzie's Avatar
The flywheel on the 8 cylinder Oldsmobile with standard transmission was the same from 1940-1948 (part number 416458). Hydramatic was different.
Before 1948 6 cyl. and 8 cyl. engines had different starter part numbers.
Ozzie is offline
roberer
September 26th, 2019 07:02 PM
roberer
July 14th, 2014 03:12 PM
37 olds
June 5th, 2014 01:48 PM
twintracks
April 26th, 2014 04:14 PM
Vader
August 9th, 2012 08:29 PM
Quick Reply: 257 inline eight starter
