Shock Absorber Oil
Old Aug 20, 2021 | 07:52 AM
Mark Desing's Avatar
Shock Absorber Oil
What do you use in place of "Delco Shock Absorber Fluid" these days? I drained and flushed the shocks on my 48 and they seem to work fine but after driving for awhile I seem to be getting some tire bounce. I used hydraulic jack oil and don't know if the oil is becoming aerated.
Old Aug 20, 2021 | 09:15 AM
Wow big difference from jack oil. The stuff that came out didn't seem that viscous but it was 70 years old.
Old Aug 20, 2021 | 10:26 AM
Hydraulic jack oil has an antifoaming additive. Some people use motorcycle front fork oil also.
Old Aug 20, 2021 | 06:31 PM
Tedd Thompson's Avatar
Or ATF it's anti foaming also. I would be leery of anything thicker than 20 wt. I could see bad things happening with anything as thick as STP. That oil has to move through tiny valves to work.... Tedd
Old Aug 21, 2021 | 08:18 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Tedd, thanks for that update. I will go back and delete my original post since it has some bad info. I have never fooled with these shocks so what I posted was some pad hearsay.
Old Aug 21, 2021 | 09:17 AM
Confirming what has already been stated regarding motorcycle fork oil. Motorcycle fork oil (cruisers/baggers/bobbers) standard weight is generally 5. Happy medium is a 7. Most often no one goes above a 10. AMSOIL sells both #5 & #10 motorcycle fork oils. H-D refers to their fork oil as “E” (just as a general statement) which I think is ~7. Can’t recall exactly. I ride an Indian and use AMSOIL #5.
Old Aug 21, 2021 | 10:33 AM
jensenracing77's Avatar
Wouldn't they have used ATF back then? I would think motorcycle back shock oil would be better than fork oil but I really do not know these vintage shocks at all.
Old Aug 21, 2021 | 11:20 AM
tnswt's Avatar
'70 4-Speed W Machine
Try contacting:
https://dansshocks.com/
Dan rebuiids spiral shocks for the HOBBY from 1953-1982 per his website, but he could have a good recommendation for hydralic oil for your '48 shocks. He rebuilt the shocks on my 442 so I know he is legit.
Good luck~
Old Aug 22, 2021 | 07:36 AM
coldwar's Avatar
Motorcycle fork oil is the answer. Out of five grades on the shelf at my local motorcycle shop, I chose one in the middle. I reuse a empty floor jack oil container with the pointed spout. Be sure to leave about 1/8" air space for expansion, and first clean off the surface where the pipe plug is located so no junk falls into fluid chamber. What a huge difference in rebound, jounce, road noise judder handling etc etc. Also no leaks suggesting compatibility with existing seals. - Good luck
Old Aug 24, 2021 | 06:13 AM
Andreas.Johansson's Avatar
I fully agree about the fork oil for bikes, over the years I have tried mixes of engine oil and STP to really high viscosity and it will for sure give you a stiff absorber but bike oil is the way to go.
If you have leaky absorbers STP+oil might be a way to minimize leakage.
nelsontj
Oct 8, 2015 04:34 AM
Robert Kiedrowski
Apr 22, 2015 10:48 AM
scooter123
Mar 5, 2014 11:23 AM
Tedd Thompson
Jun 14, 2012 07:28 PM
Rickman48
Apr 13, 2012 10:05 AM
