Oldsmobile 61 dynamic 88
can anyone help me in locating the fuel pump on my 61 olds dynamic 88. I’m aware it doesn’t have an easy access panel but I want to cut one out for myself.
problem is the car was originally under coated and it’s still in perfect shape down there. Thanks in advance.
Another option is to ship your current mechanical pump to a rebuilder:
Fuel Pump Rebuilding (egge.com)
Fuel Pump Rebuilding - The Classic Preservation Coalition
If you can bend over the fender (Right hand side) you should be able to reach it with a 1/2 inch wrench or if you have access to a lift even easier from the bottom, Two bolts and a gas line and you are done....Tedd
