Not feeling horny
Old Feb 6, 2026 | 03:40 AM
OldsMcDonald's Avatar
From: In the Uk in an area called The Midlands (which are in the middle :-))
Not feeling horny
My horn has stopped working. I’ve checked & tested the horn push, relay and the horns themselves and everything works. I think I’ve traced it down to the horn connection within the steering column - 2.859 in the attached image. Does anyone know if I have to remove the complete steering column to access this?
Old Feb 6, 2026 | 05:15 AM
chopolds's Avatar
First, I would use an Ohm meter to be sure if the wire is not broken inside the column. If it is, you can try fishing a thin wire from either top or bottom, all the way through, then tape a new wire onto the end of it, and pull it through. Should work then.
Are you sure you are testing it correctly? Lots of folks think that the wire from the horn button to the relay is a hot (+) wire. It isn't, it's a ground. So in testing, you can also use an ohm meter (or continuity tester) to check all points along the way to the relay, from the horn button. Also be sure the horn button is hitting a good ground when it is pressed!
Old Feb 6, 2026 | 08:00 AM
jensenracing77's Avatar
For sure test the wire first. I am not sure what the contacts look like on your model year but often the 61-63 f-85 cars have corrosion in the buttons on the steering wheel. I take them apart and clean them up and typically work like new after that.
piperman60
Jul 23, 2020 08:44 PM
Toocool
Feb 27, 2018 06:20 AM
Kurtzk
Feb 3, 2017 04:01 PM
tschie
Tech Editor's Desk
Nov 11, 2015 04:35 AM
Hoffman2099
Oct 2, 2015 04:11 PM
