New power disc brakes
Proportional valve installed and new brake lines manufactured
Bracket for brake calipers installed
All assembled together
Installation of the Autronic Eye on the old heater box
All assembled for trial
I still had an old heating box, which I modified and then reinstalled the Autronic Exe. Had to adjust it a bit
Water drain installed
Check the base plate for assembly accuracy
finished cutout
Marked where the main brake cylinder will go. Is not ideal, so cut out more
Removed fresh air part
Removed Heather Box on the driver side
L77F85
June 9th, 2014 12:44 PM
1956olds88post
Brakes/Hydraulic Systems
August 22nd, 2013 06:33 PM
