Need help identifying 1954-55 water pump pulley
Hi All
I was contacted by an Olds owner in New Zealand. He's needing a power steering pump and water pump pulley. I've come up with a power steering pump, but am not sure this is the correct pulley. Its 8" across, about 1 3/8" wide for the pulley grooves, then about 3 3/8" deep on the pulley. Attached are a few photos. I know the tape measure isn't the most precise, but am hoping this is close enough that I can have some confidence its right before shipping it halfway around the world! John
If it came off one of your 55-54's it should fit fine, I went out and took a look at my 55, and it looks identical. I don't have a Hollander, but they should all be the same except the one for A/C engines... Tedd
yeahbuddy
February 18th, 2022 11:47 AM
