Need help identifying 1954-55 water pump pulley
Old Feb 20, 2022 | 02:08 PM
2blu442's Avatar
Hi All
I was contacted by an Olds owner in New Zealand. He's needing a power steering pump and water pump pulley. I've come up with a power steering pump, but am not sure this is the correct pulley. Its 8" across, about 1 3/8" wide for the pulley grooves, then about 3 3/8" deep on the pulley. Attached are a few photos. I know the tape measure isn't the most precise, but am hoping this is close enough that I can have some confidence its right before shipping it halfway around the world! John
Old Feb 20, 2022 | 04:00 PM
Tedd Thompson's Avatar
If it came off one of your 55-54's it should fit fine, I went out and took a look at my 55, and it looks identical. I don't have a Hollander, but they should all be the same except the one for A/C engines... Tedd
Old Feb 20, 2022 | 04:07 PM
2blu442's Avatar
Thank you Tedd. I'm 99% sure I removed it from the 1954 324. But after thinking a 1950's Chevy starter was an Oldsmobile 324 starter I'm not counting on my memory!
Old Feb 20, 2022 | 05:23 PM
Charlie Jones's Avatar
Phantom Phixer
The Oldsmobile Chassis parts catalog shows that all two groove pulleys from 1952 thru 1962 are the same.
Part number 571396.
Old Feb 20, 2022 | 05:31 PM
2blu442's Avatar
Part number 571396.
Thank you Charlie!
yeahbuddy
Feb 18, 2022 11:47 AM
Kocht
Jul 22, 2021 07:59 AM
Allan R
Oct 8, 2019 12:52 PM
harry k
Nov 11, 2018 01:29 PM
gbledsoe3
May 24, 2017 02:04 PM
