Need help with a 1956 power antenna
Old Jul 2, 2024 | 12:58 PM
The_German's Avatar
Can you guys help me with the repair of a 1956 power antenna? Any construction drawings, exploded views, repair help? Seems that the nylon cord is out of the antenna hanging down and the aluminum tube is off.
How does that go together?
Thanks so much!
Old Jul 2, 2024 | 06:13 PM
Charlie Jones's Avatar
Phantom Phixer
I have this illustration from the parts book, if it helps. The one on the upper left.
Also, be aware that there were two separate manufacturers of power antennas used by Oldsmobile in 1956.
They were Casco and Pioneer.
The following pages denote some information and part numbers
Old Jul 3, 2024 | 01:05 AM
The_German's Avatar
Thanks so much, but it seems that the antenna that you show is a different one. I was told that the above (see photos) is the real 1956...
Old Jul 3, 2024 | 07:27 AM
Phantom Phixer
Yes indeed, The illustration is for 1958, but it's the only one I had of a power antenna.
If you scrape enough dirt off the motor unit, you may find a data tag.
It should list the manufacturer as well as a model number.
Old Jul 3, 2024 | 07:40 AM
Phantom Phixer
Here's an antenna mast repair kit, IF you have a Pioneer antenna.
1956 OLDSMOBILE Power Antenna Mast Repair Kit STANDARD | eBay
Old Jul 3, 2024 | 09:44 AM
BeenThere's Avatar
1956 Power Antenna Pictures
Old Jul 3, 2024 | 09:58 AM
BeenThere's Avatar
1954-1956 Casco type
442Harv
May 22, 2023 10:37 AM
marzgtp1
Mar 9, 2023 01:27 PM
Clutch Cargo
Feb 21, 2023 07:10 AM
The_German
Apr 18, 2014 09:16 AM
