Marking its territory
Old Dec 30, 2020 | 10:15 AM
maineolds's Avatar
My 1949 Olds 88 with the 303 likes to mark its territory... I’ve got an oil leak out of the front of the engine, close by the harmonic balancer. I guess I’ll have to do something about it some time. Is this a typical leak site?
another question, on the rear right (passenger) side of the engine there’s what looks like a small exhaust tube. The kind you’d see on a small RV generator. I assume it’s some sort of crank case breather. Am I correct? It drips the blackest oil ever! It doesn’t gush out, but it steadily drips out after a drive. Thoughts?
Old Dec 30, 2020 | 10:42 AM
Sugar Bear's Avatar
Yes the tube is a breather. You could fashion a catch can there and empty it periodically just don't forget it's there.
Harmonic balancers are common leak points on most engines. As I don't have experience in that gen engine I would like to see what others have to suggest.
Good luck!!!
Old Dec 30, 2020 | 11:10 AM
rocketraider's Avatar
Oldsdruid
The tube at right rear is the engine's crankcase ventilation system. Commonly called road draft tube.
Before the days of positive crankcase Ventilation, engines still had to have a way to evacuate crankcase fumes and blowby. The oil fill cap was usually used as the fresh air intake for the engine. Look at the open end of the road draft tube and you'll see it's cut at an angle. When the car was moving, airflow under it created a scavenge at the road draft tube, pulling fresh air in thru the oil cap, thru the engine, and out the draft tube. When the car wasn't moving, no scavenge and the blowby smoke would often make you think the car was on fire if engine was really worn.
These draft tubes are why the middle of road lanes always looked oily in those days.
Keep the oil fill cap clean and system ought to function per design. Wash it in solvent, dry it and reoil it. Not much you can do to the tube itself short of pulling the intake and valley cover.
Old Dec 30, 2020 | 02:48 PM
maineolds's Avatar
Great info! Thank you
Old Dec 30, 2020 | 07:03 PM
maineolds's Avatar
Would the seal under the harmonic balancer be called the timing cover seal?
https://www.napaonline.com/en/p/NOS1...ront+main+seal
it seems to be called the crankshaft front oil seal in the service manual.
Old Dec 30, 2020 | 08:59 PM
redoldsman's Avatar
Proud Viet Nam Veteran
One in the same.
Old Jan 2, 2021 | 11:08 AM
maineolds's Avatar
Just thought I’d update people that may search this post in the future. I’ve moved discussion on how to access the front main seal to another thread called “harmonic balancer removal”.
Brownie12
Apr 15, 2020 06:37 PM
jcormier89
Dec 29, 2015 08:53 PM
thapachuco
Feb 15, 2013 07:42 PM
BradyB
Sep 25, 2012 09:03 AM
scooter123
Mar 22, 2012 10:21 AM
