Idle Problems
Old Jul 24, 2020 | 12:53 PM
tricordati's Avatar
Idle Problems
My 1956 88 at operating temp idles fine in park but when in gear stalls at a stoplight...thoughts/suggestions? Thanks
Old Jul 24, 2020 | 01:09 PM
I can't say specifically, but what "generally" occurs with any of the older/vintage vehicles I've owned (including the 4-4-2's and older vehicles when I was a young man) and my current '71 CS, when the idle begins to get a little rough, and it starts to lobe a little more, it's time for a full tune-up: Rotor, points, distributor cap and (1) Dwell>(2)Timing>(3)A/F Mixture Screws (achieve the highest vacuum possible). My experience has >90% of the time demonstrated it was nothing more than a tune-up was all it took. I mean, seriously, it could be nothing more than adjusting the slow idle screw and increasing the RPM, but it's nearly always been nothing more than a good tune-up.
Mine will often get to the point where it gets wavy-gravy on going into drive w/o stalling, but then I again I keep my idle a tad lower than I believe most folks do.
Old Jul 24, 2020 | 02:55 PM
As Norm stated, when was the last time it was tuned up? What settings were used?
Old Jul 24, 2020 | 05:57 PM
Tedd Thompson's Avatar
Do you know what RPM it is set on now. Pretty simple to adjust the idle screw and bring up the RPMs a little and see before you start buying parts. I like just a very slight creep on level round when in gear, shouldn't ever stall on a stop.... Tedd
chenner
Mar 30, 2020 06:20 AM
n_holman
Oct 5, 2014 11:38 AM
AZ455
Nov 3, 2011 06:24 AM
BB Blue 67
Aug 25, 2011 01:29 PM
66ninetyeightls
Aug 23, 2010 12:24 AM
