help with feul pump vacume lines
I have a bad case of crs,one line goes to the wipers i know, but i dont know which one.Havent got the second line so far as i can tell so ill have to make one.Anybody with a 55-56 that can get me a few pics would be great,which one goes where on the fuel pump and where do they go?
Unfortunately the digital camera is smarter than I am, so I can't supply pictures... One of those lines indeed goes to the wiper motor, the other goes to the vacuum tree that is threaded into the base of the carb in the rear. I think looking at it from the front of the car the left one goes to the motor and the right one goes to the vacuum tree... Could be wrong though. I will be more specific when I get a chance to take a peek at mine.
Maybe the pictures and diagram here will help: https://classicoldsmobile.com/forums...olds-88-a.html
I believe Oldsmobum is correct.I also am missing my car so this is a memory thing. My carb is a f4g and the fitting attachés to the rear of the carb.You may not have that fitting on a non stock three carb setup, can't tell from your avatar picture. If wipers are a must(and they are for me) you might look into a electric wiper conversion. I have been told( disclaimer inserted here) that 55 ,56 57 Chevy is a easy modification to a Olds and thats on my bucket list for this winter....Tedd
Ok i run one from pump to wipers and tee it off to wiper switch and heat valve i think, and one to base of center carb right.do you think there is a differance witch line goes to which or do they draw the same vacume on either side?Thanks for the replys,got my new carb bases and linkage today so i will be ready sunday to turn the key i hope.
vac. lines
Carb guy says if it drops below 2lbs wipers wont work .I only need vacume to 1 carb so mabey the pump evens out the distribution between carb and wiper functions.The pump is for backup when cruising the vacume from the engine drops,at idle it goes up,or so ive heard.
Your vacuum pump is for the wipers and that is it. It is so that the vacuum to it is constant unlike manifold source vacuum. That way your wipers wouldn't slow down or stop due to inconsistent vacuum.
