So a few years ago I bought a original Fulton sun visor in Pomona.
Last night I finally decided to install it on the car. Everything was pretty straight forward till I had to do the supports in the middle.
It was pretty hard to get the brackets in between the chrome and the rubber but I quickly noticed that the brackets are too far apart.
I measured the chrome trim and it's about 30mm wide (1.18 inch) and when I hold the bracket together as it should sit it's like 0.7 inch (around 17mm)
I found some other brackets on ebay and they seem to be the same width.
As you can see on the photo's the lower bolt will be hard to impossible to install.
Any advice on the brackets? Do I need special brackets for the olds? Or IF somebody has one installed could you please send some detailed photos of the clamps on the post maybe that would already solve the question marks.
