Distributor on 55 olds
Old Jan 3, 2024 | 07:26 AM
Super88chris's Avatar
Are the advance weights under the base plate in the distributor on the 55 olds super 88? If so can they be checked or what reasons would the need to be addressed ?
Old Jan 3, 2024 | 07:12 PM
Charlie Jones's Avatar
Phantom Phixer
Yes they are.
There's a quick way to check this advance mechanism.
Remove the cap and try to move the rotor backwards from the normal rotation (counterclockwise).
If it moves backward several degrees and then springs back, it's OK.
If not, the distributor should be disassembled and the cause determined.
Old Jan 3, 2024 | 07:32 PM
Yes they are.
oh wow ok I’ll check that tomorrow thank you for the advice
ranmat2
Nov 22, 2016 07:26 PM
fatback
Nov 13, 2016 05:15 PM
fatback
Jun 9, 2016 12:07 AM
ortarheel
Feb 26, 2015 08:33 AM
Bosco1956
Oct 17, 2008 09:57 PM
