Changing Pan Gaskets on '55 Hydra-matic
Old Sep 7, 2023 | 08:50 AM
madmax442.com's Avatar
madmax442.com
Finally getting to this. The side pan was leaking fairly bad, super annoying. I marked a line on the linkage brackets, there are 2 you have to remove, then the side pan comes right off. The linkage shaft is sealed from behind by a big rubber washer (that was not leaking). I decided to clean the pans with a hard sponge type grinding wheel. Primer and paint, used VHT aluminum ( prob not factory correct). Found gaskets and seal kit on ebay, installing later today. Five of the side pan bolts have copper washers that go on the lower half. Looks like all the factory bolts were still there!
Old Sep 7, 2023 | 12:27 PM
madmax442.com
Got it back together, will add fluid and test tomorrow. Not taking any chances, using a thin coat of Aviation Petmatex.
Old Sep 7, 2023 | 04:32 PM
Charlie Jones's Avatar
Phantom Phixer
That trans looks pretty clean inside for something almost 70 years old.
I'm sure it will serve you well into the future.
Old Sep 8, 2023 | 03:07 AM
That's excellent that you can remove both pans with the transmission in the car. If only Oldsmobile had stuck with that wisdom for the following 40+ years.
rktrde303
Feb 15, 2023 01:29 PM
Bill G
Jun 14, 2022 03:01 AM
tgilligan
Sep 13, 2020 07:10 AM
Tech Editor's Desk
Aug 17, 2020 12:33 PM
Feb 18, 2019 09:39 AM
