Carb colouration
Old Aug 17, 2025 | 01:37 PM
OldsMcDonald's Avatar
From: In the Uk in an area called The Midlands (which are in the middle :-))
Carb colouration
Does any one have any ideas as to what would cause the smoky grey/white deposits in the barrels of my Rochester AA on a 1950 Rocket 88? I stripped the carb down because, once it gets warm, it’s hesitating at anything over 40mph.
Old Aug 17, 2025 | 01:45 PM
I don't see any abnormal wear on the carburetor in the pic. You can see where the throttle plates have slightly worn the carburetor bores moving over years and years. I'd be more concerned about the throttle shaft bushings than that wear though.
Old Aug 17, 2025 | 01:59 PM
OLDSter Ralph's Avatar
I am going to guess the deposits are from the additives in the petrol you use across the pond. I would think a dab of SimiChrome would remove the deposits.
Now would be a good time to check throttle shaft looseness.
JLawrence
Dec 24, 2024 03:54 PM
57J2Olds
Aug 2, 2023 09:50 AM
jmcghee
Feb 3, 2022 06:57 PM
skyhigh
Oct 12, 2020 10:27 AM
