55 Super 88 speedometer jumps randomly
Old Apr 10, 2021 | 08:26 PM
fredb_'s Avatar
My speedometer works pretty well other than being a little fast. It occasionally will make some noise and act erratic. I removed the inner cable which looks fine and added a little light grease. During a 50 mile drive it still would occasionally make a whirring sound and the speedometer would bounce. Any ideas on what is causing this? I was thinking maybe dry gears inside speedometer.
Old Apr 10, 2021 | 09:07 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I would have guessed the cable. Did you pull it all the way out and lube the entire cable?
Old Apr 10, 2021 | 09:25 PM
fredb_'s Avatar
Yes, pulled it completely out of the housing and wasn’t really dry. Put a light coat of some light grease on it and slid it back in.
Old Apr 10, 2021 | 10:31 PM
Ozzie's Avatar
The 1955 Oldsmobile Shop Manual has a procedure for lubricating the speedometer cable on page 2-10, which includes cleaning old grease from the casing and lubricating the lower 2/3 of the cable. Your description makes me think that it may be a problem in the head. If you're good with delicate mechanisms, you may want to tackle it, or send it to a speedometer shop.
Old Feb 24, 2022 | 08:22 PM
DFitz's Avatar
74 2.8L Capri
Mine was doing exactly the same thing, then the needle fell off! Sucks. Anyway, did you ever figure out the culprit?
I'm in the middle of putting in a new speedo cable.
Old Feb 25, 2022 | 07:45 AM
DFitz's Avatar
74 2.8L Capri
Anyone have a recommendation on where to send the speedometer for rebuild?
The SF bay area places no longer have parts.
Old Feb 25, 2022 | 07:50 AM
NTXOlds's Avatar
Give these guys a call:
http://www.zepco.com
They are in Dallas and do good work. I am not sure how much they are doing on older cars these days, but they worked on my son's Cherokee. They did very good work.
Old Feb 25, 2022 | 08:23 AM
DFitz's Avatar
74 2.8L Capri
Thanks.
Old Feb 25, 2022 | 03:17 PM
DaveD65's Avatar
I just had my speedometer repaired at Redline Gauge and Clock Repair in Greenbush, Mi. John services all GM's from the 30's through 80"s. He has parts on hand and does good work.
Old Feb 26, 2022 | 07:25 AM
DFitz's Avatar
74 2.8L Capri
Thanks. Palo Alto Speedometer recommended a place in LA, Redline Gauge Works. Sent it off yesterday to be rebuilt. I don't know if the companies are related.
dddddyang
Mar 3, 2020 10:15 AM
Bseward78
Jan 26, 2017 06:53 PM
Rocketbrian
Jan 11, 2016 08:34 PM
R_CK_R
Aug 18, 2014 08:59 AM
David Man-Man Manley
May 11, 2013 06:02 AM
