55' Olds power/manual steering gear
Old Apr 15, 2022 | 09:24 AM
ub2693v's Avatar
This may seem silly to a lot of you out there but i am toying with the idea of dumping my power steering in favor of manual steering. I like the road feel and simplicity with manual steering, i see units pop up from time to time but before i pull the trigger, does anyone know if the non power steering shaft is a different diameter than the power steering one so I would be able to keep the interior bits or would i need to find a non power steering car to do the whole swap?
Old Apr 15, 2022 | 05:44 PM
Charlie Jones's Avatar
Phantom Phixer
Practically everything from the steering wheel down is different , power vs.. manual in 1955.
The entire steering column would have to be removed and replaced .
The steering gear box is not separate from the column, as in later models.
You will have to tear apart a lot of stuff.
If you did want to install manual steering, there are probably a lot of guys with manual steering that would like to trade parts.
Old Apr 18, 2022 | 06:44 AM
ub2693v's Avatar
Good idea, maybe i'll go the trade route, its all removed anyway.
Thanks!!
Old Apr 18, 2022 | 08:07 AM
Tedd Thompson's Avatar
You have to be Lance Armstrong to turn a 55 in tight places, once moving not a issue, but from a stop you know why they put that huge steering wheel in there... Tedd
Erik Andersen
Mar 17, 2022 10:12 AM
edzolz
Apr 22, 2018 03:42 PM
4speedBench
Nov 20, 2014 08:25 AM
Mikep442
Suspension & Handling
Apr 7, 2014 06:15 PM
BCFKody
Oct 31, 2012 11:04 AM
