55’ olds 324, pulled valve covers, all valves closed?!?
Old Oct 3, 2019 | 03:54 PM
ub2693v's Avatar
Why would all the valves be closed if the cam shaft is still in the engine? I can rotate all the push rods and can move the rockers downward against the lifters, is it because all the oil is out of the lifters? I’m talking all 16 valves, currently I am trying to get the engine freed up and this doesn’t make any sense to me.
Old Oct 3, 2019 | 04:18 PM
Sugar Bear's Avatar
Yes the lifters probably bled down if it sat for long. Sounds like a candidate for priming the oil pump. Good luck with freeing it up...patience...patience and persistence, hopefully you get it to turn.
Old Oct 3, 2019 | 08:21 PM
Tedd Thompson's Avatar
A priming tool can be made from a scrap distributor shaft if you have one you don't need. The Old's has that D shaped end that matches up with the oil pump. For some reason it takes awhile grinding away to get oil to the lifters and beyond on a 324. Takes patience to be a Oldsmobile man... Tedd
Old Oct 3, 2019 | 09:09 PM
redoldsman's Avatar
Proud Viet Nam Veteran
And be sure you turn the pump counter clockwise.
Old Oct 4, 2019 | 08:02 AM
Good catch, It didn't cross my mind... Tedd
Old Oct 7, 2019 | 04:56 AM
ub2693v's Avatar
Thanks guys, I will give it a try!!
fatback
Apr 15, 2015 11:38 AM
Jen
Dec 3, 2012 03:27 PM
jaygtx440
Sep 21, 2012 09:07 PM
Nasty455
May 23, 2012 03:09 PM
dallasite21
Jul 10, 2011 08:26 AM
