'55 Front Suspension ans Steering Overhaul - pics!
Old Nov 27, 2023 | 11:16 AM
madmax442.com's Avatar
madmax442.com
'55 Front Suspension and Steering Overhaul - pics!
Took me about 3 weeks doing this on weekends and nights. I am going to post a bunch of before and after pics. I did ream the kingpin bushings with a reamer. Used an entire shaft kit, new spings/shocks, and a steering cup kit.
After:
Old Nov 27, 2023 | 11:31 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Very nice job. You probably had some old grease on there dating back to the fifties. .
Old Nov 27, 2023 | 11:31 PM
58SnowWhite's Avatar
Wow!! That's amazing!! How did you manage to get parts??? I have a 58 and I'm having a hard time looking for parts.
Old Nov 28, 2023 | 06:10 AM
ub2693v's Avatar
looks awesome!! Just reminded me to order the rubber splash guards!
Old Nov 28, 2023 | 07:29 AM
Charlie Jones's Avatar
Phantom Phixer
How many miles are on that car?
It doesn't look like there was a lot of wear on those old parts.
Any way, it will look and function like new now.
Old Nov 28, 2023 | 08:57 AM
madmax442.com
92K, it was well cared for no doubt. They greased the heck out of the front end over the years, thus all the muck. Everything did clean up very well. I am happy with the outcome. Taking it to the alignment shop on Thursday, bought the upper king pin caster/camber wrench on ebay.
Old Nov 28, 2023 | 09:13 AM
madmax442.com
So, the shaft kit can be found at Fusick or on ebay. I bought mine on ebay. I bought the springs and insulators from Eaton Detroit Springs. I bought the lower control arm rubber bumpers off ebay, advertised for a Buick but they were almost an exact match. I bought the idler arm and other misc stuff from Fusick. I found toe adjustment couplings on ebay as NOS, they were Moog. The outer tie rods are available anywhere still. I bought the shocks off RockAuto. You do have to reuse your inner tie rod ends, I was lucky the ball ends were not worn that much, they cleaned up. The wheel cylinder kits were Dorman and only a few bucks, can still be found anywhere. I had to buy the kingpin long reamer from iscuttingtools.com that was $120, ouch. The 'ole one time use tool, gotta love that.
Old Nov 29, 2023 | 01:19 PM
BobsFiftyEight's Avatar
Tool Freek
@madmax442.com You did an awesome job,
Please could you post a photo of the caster/camber wrench you purchased on ebay?
Bob
Old Nov 29, 2023 | 02:47 PM
madmax442.com
Sorry for the tiny picture, ebay took the old post down. It's Kent Moore J-5343 if you need to search for one.
Old Nov 29, 2023 | 06:32 PM
justacog's Avatar
That looks fantastic! One of my upcoming projects is exactly this! I've all of the replacement parts. Mines a 1954 with the front hydraulic shocks which I've not yet checked out (they might need a visit to Apple Hydraulics for a rebuild). Beautiful job :-)
Old Nov 30, 2023 | 09:38 AM
Tool Freek
Thanks for posting the photo of the tool and listing the Kent Moore tool number.
I can see how it would be needed to adjust camber/caster in one of your photos, pretty cool stuff.
Bob
Old Dec 7, 2023 | 01:22 PM
justacog's Avatar
Well Madmax442 has inspired me (along with some handling/suspension issues) to redo the whole front end of my 1954 Olds Super 88. I've got everything apart and am finishing up the cleaning of the parts (most of the work is scraping off a bad undercoating job done around 1960) before painting. Lever arm shocks are off to Apple Hydraulics for rebuild as well (they were pretty leaky).
I've got a question however. After cleaning the cross link bar, I found what looks to be factory green paint on it. Which of these steering/suspension parts were paint something other than black? Attached are some photos of the crosslink bar. The car paint is Glacier Green/Polar White. The oil pan seems to be painted the same Glacier Green (I found after removing the undercoating). However the green on the cross link is more of an emerald green like the paint on the dash.
I'd like to try to keep things as reasonably original, particularly if it's just choosing the right color for the right parts on the undercarriage. Any thoughts?
Factory green paint on crosslink bar
Old Dec 7, 2023 | 01:57 PM
madmax442.com
So, I too want to keep my '55 as close to original also, but I did not research the paint colors on the suspension/steering components (shame on me). I, however, did not see any green paint on any of my parts. I see a yellow marking on the steering linkage between the spindle and outer tie rod end, but I did not replicate that either.
I would suggest 2 options. VHT makes a Chassis Black (semi-gloss) that I like. I actually used Rust-o-leum Rust converter as a primer on most of my parts, then used VHT Gloss Black engine paint on most everything you see in my pictures. The VHT Engine paint lays on so well in my opinion, its forgiving and looks really well, again in my opinion. I am sure the Olds paint czar out there know the exact paint code, but for my I liked the gloss black engine paint, with option 2 being that semi-gloss Roll Bar and Chassis paint from VHT (I bought it from Autozone).
My only other thought would be the '54 and '55 324s are painted that same color green and it "may have been" overspray? The steering center tube runs right up next to the oil pan. I have see many engines retouched up with paint and that could have happened, albeit your looks like that first layer from back in the day.
Old Dec 7, 2023 | 06:22 PM
Phantom Phixer
All these suspension parts were either sprayed or dipped in the cheapest black paint available.
The green paint was either an identifying mark or an inspector's mark.
If you want to duplicate it, get a small brush and some green paint and just dab it on.
Old Dec 8, 2023 | 06:48 AM
justacog's Avatar
So black it is. Any recommendations for semi-gloss vs. gloss black?
Old Dec 9, 2023 | 12:12 PM
DFitz's Avatar
74 2.8L Capri
Agreed, all my suspension parts were black. Very original and ummolested when I was doing the work. It could be the overspray from the engine at the factory, as was suggested, but my thinking would be someone touched up the engine/trans/pan at some point and that's when you got some overpray.
Believe it or not, I used Rustoleum primer, and Satin black. Came out very nice.
This was from a few years ago.
mrolds69
Nov 24, 2021 03:13 PM
72455
Nov 9, 2021 09:46 AM
Kada
Jul 11, 2021 10:15 AM
oldsguybry
Sep 16, 2012 08:09 PM
Olds65
Aug 11, 2012 06:55 AM
