'55 Leaf Spring Install - cut the bolt?
Old Dec 2, 2023 | 05:04 PM
madmax442.com's Avatar
madmax442.com
Bought new leaf springs, realized after I tried to raise to diff after I removed the u bolts, the springs have the center bolt between the axle housing and the plate (part of the car) holding the springs on. I able to just remove the nut, but the bolt sits there with no way to remove, like its pressed in. Should I just cut this bolt and try to fish it out of there? Weird, wasn't expecting that. New springs just have a bolt already installed.
Old Dec 4, 2023 | 05:13 AM
ub2693v's Avatar
When i did mine there was no bolt in that spot, just a "nub" instead of a hex head on the center of the stack that aligned into that hole, unfortunately i don't have any pictures of it.
Old Dec 4, 2023 | 05:44 AM
chopolds's Avatar
That HAS to be the bolt that held the spring pack together, Located the perch on the rear end. So, you can cut it off, but then you would have to remove the "head" from the perch. Probably easier to soak it, and pound it out, so the hole doesn't get "lost" or damaged.
Old Dec 4, 2023 | 06:31 AM
gs72's Avatar
72Cutlass S
Or bolt the old spring back together on the perch and use the spring as a lever to work the head of the bolt out of the perch.
Old Dec 4, 2023 | 07:08 AM
madmax442.com
Yes, I had to remove the nut to get the springs off. I can't really remove the center bolt from my new springs, thats not a good option, so time to cut I guess. The head is a nub that press fit from the factory on the perch before they welded the perch to the axle housing, so this bolt is completely non-serviceable. It will hit the axle tube if I pound it out from the bottom so I will need to cut the bolt, then chisel the head off, then remove it with a punch from the bottom. Still completely weird to me why Olds did this.
Old Dec 4, 2023 | 07:55 AM
2blu442's Avatar
I've got several loose rear ends from 1954 and 1955 Oldsmobile's and none have that bolt attached to the housing. Have you tried tapping the side of the bolt, or trying to pry it loose from the housing? Here's photos of that plate on a couple of them.
Old Dec 4, 2023 | 07:56 AM
ub2693v's Avatar
the only picture i have of the rear end, there was no bolt welded where yours has a bolt.
Old Dec 4, 2023 | 10:19 AM
madmax442.com
The bolt has a a head on it, kind of like rivet head, it's definitely pressed in. Since it's directly under the axle housing, there is no clearance to remove it without cutting and knocking the head off of it. It's a little comforting to see other housings the same year without it, so when I cut, drill, or punch this out, I won't feel as bad. I will post more close up pictures tonight.
Old Dec 4, 2023 | 10:52 AM
gs72's Avatar
72Cutlass S
It is probably stuck in there due to rust. If you cut it off you loose all the leverage to work it out of there.
Old Dec 4, 2023 | 11:41 AM
madmax442.com
No, its not stuck, its a press fit. That's how you are able to loosen the nut without the stud turning. I will add a pic tonight that shows the top of the stud/bolt.
Old Dec 4, 2023 | 04:47 PM
madmax442.com
Ok first of all thank you everyone, I am relatively new to working on 1950s cars, things are different, but in most cases simple. I was able to knock the bolts out from the bottom. They do hit the housing but I kept pounding and they came out at a angle. The bolts are definately hardened, me wacking on the with a hammer didnt even damage the threads. The hole is .500, same as new springs center bolt cap, so the new springs will center right up.
Old Dec 6, 2023 | 09:36 AM
madmax442.com
I used 7" u bolts that were almost too short, but it worked out. So, all done!
Reused the spring insulators, they seems fine. Test drive checked out great today.
Old Dec 6, 2023 | 10:00 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I would say those ubolts are just right. You have a couple threads sticking out beyond the nut and that is perfect. Congrats
Old Dec 7, 2023 | 09:26 AM
madmax442.com
BEFORE
AFTER (Look at rear tire whitewall, you can see top of hubcap now too)
Old Dec 9, 2023 | 12:19 PM
DFitz's Avatar
74 2.8L Capri
Originally Posted by madmax442.com
BEFORE
Very beautiful car. Nicely done. I had a very similar experience. Had to tap out that bolt form the hole, at an angle. This was after the old springs sagged enough the drive shaft was hitting the underbody when the back seat was occupied.
But I had a very interesting complication. Someone at the factory had managed to get the Rt spring in backwards! It was all deformed because the direction was wrong and had the majority of the heavier springs at the bumper end. It does much better now. No grinding noises.
seanm12
Brakes/Hydraulic Systems
Apr 10, 2021 05:50 AM
Tjohn8573
Sep 13, 2019 02:31 PM
D. Yaros
Sep 10, 2016 04:41 AM
RandyS
Suspension & Handling
16
Feb 15, 2015 10:33 AM
hvysupreme
Apr 11, 2012 04:47 PM
