4gc Carb Rebuild
Old May 10, 2010 | 02:54 PM
jaymann's Avatar
4gc Carb Rebuild
Think this carb needed a rebuild! I know I haven't seen one in worse shape.
On top of the fuel bowls being full of sludge and varnish, someone previously rebuilt the carb using gasket sealer. They also messed up the linkage and missed one of the two check *****.
It took me a full day of cleaning and scrubbing to get those bowls clean.
It's back together and I'm still doing on car adjustments.
The shop manual was invaluable when it came to tearing this down, although it did miss a few things and didn't quite explain somethings clearly.
Overall not a bad carb to rebuild. I think a Quadrajet is way more complicated.
Old May 10, 2010 | 07:47 PM
OLD SKL 69's Avatar
GM Enthusiast
I know what you mean, these are pretty straightforward to rebuild. Yours does look yummy inside!
Old May 10, 2010 | 08:24 PM
Blk71SX's Avatar
when that carb was new, everything was simpler
Old May 12, 2010 | 07:12 AM
D. Yaros's Avatar
As I am doing a similar rebuild on a 4GC on a Cadillac, I would be interested in learning the location of the 2 check ***** you referenced. I ask, as when I tore mine down, I found only 1. It was located under the T-bar plate shown in your picture in the venture cluster mounting area. Where was the second?
Old May 12, 2010 | 08:11 AM
aliensatemybuick's Avatar
"me somebody" site member
The second check ball should be at the bottom of the accelerator pump well (right under the bottom spring). There is a continuous passage between check ***** (which I imagine is how the accelator pumop works).
Old May 12, 2010 | 09:04 AM
jaymann's Avatar
Yup...the two check ***** are under the T-bar and under the spring in the accelerator pump well.
Mine was missing the check ball in the accelerator pump well.
There are 2 different sized check *****. In my kit the T-bar ball was steel and the pump was aluminum looking.
Old May 12, 2010 | 12:12 PM
Correct. The aluminum ball goes in the bottom of pump well, under the pump return spring. The steel ball goes under the T-bar. I just went through this on the 4GC for my 215.
As for comparisons with a Qjet, I'll take the Qjet any day. One float to worry about, not four, for example. Maybe I'm just more used to rebuilding Qjets.
viper771
Nov 30, 2012 08:52 PM
viper771
Nov 17, 2012 03:45 PM
Hal Robinson
Feb 24, 2009 08:51 AM
skubydobdo
Sep 19, 2008 06:15 AM
sanemb
May 28, 2008 05:43 PM
