371 Engine Clearance
私は 1957 年製オールズモビル 371 エンジンを再構築中です。
メインベアリングとロッドベアリングの隙間を教えて下さい。
I'm rebuilding a 1957 Oldsmobile 371 engine.
What is the gap between the main bearing and the rod bearing?
Last edited by oldcutlass; October 23rd, 2023 at 04:47 AM. Reason: edited in translation
I need a little more information, Is this a stock 371 crank rod combo or a punched out 324? Do you have the new parts now? Is there an equivalent to what we have here in the states called Plastic Gauge where you are located ( Plastic tape used to measure bearing clearances)?. In general about 2- 3 thousands for rods but you need to check this with the correct manual, it doesn't sound like you have a compleat detailed manual for internal engine parts for your engine Or something is lost in translation.. Tedd
