324 pulling help!!
324 pulling help!!
Got everything set up last night, removed all engine mounts and all bolts holding the transmission to the engine. Attempted removing engine, but the transmission doesn't want to let go of the engine. What am I missing here? Never pulled an engine this old before, did I miss a step?
x2 what Olds Dad said, but I always pull the trans and engine together. For me it's easier and faster than laying on my back working in a confined space removing those 28 bolts. Plus once everything is out you can move the car around if need be, otherwise you will need to support the transmission with a jack and your car is stuck where it sits.Just a thought...Tedd
When you pull those together, your better have a good hoist because you are talking a lot of weight. The old hydramatic has to be several hundred pounds plus the engine. I bet the two of them together is close to 1,000 pounds. If I ever have to pull the engine, I think I would do it your way Tedd.
nj_cutlass72
Oct 21, 2012 10:08 PM
denf221
May 2, 2010 06:39 PM
....Tedd
