1962 Dynamic 88 transmission swap and engine mount?
Old Mar 21, 2025 | 04:08 PM
rapoport05's Avatar
Hey all, I have a 62 dynamic 88 convertible, I'm looking to build it into a higher powered cruiser.
Here's the ultimate goal: 394 high compression engine with a tri power (i have a demon tri power carb set up and an offenhauser manifold, but i might switch to rochester carbs if needed), fabricating my own headers (might end up being log style, not sure) dual exhaust, TREMEC TKX 5 speed, and fabtech 3.73 posi in the factory rear end. It will ultimately have tubular control arms, disc brakes on all 4 wheels, etc etc etc.
Here's the dilemma: if I put the manual transmission (or any other swap for that matter) behind the 394 do I attempt to keep the front and rear engine mounts as well as a transmission mount? Or do I use a hurst style envying mount up front, delete the rear engine mount, and have the transmission support the back?
I'm not opposed to fabrication, I know this will be a big undertaking, and I'm 100% set on putting a third pedal into the car.
currently the car is a low compression engine, slim jim tranny, bench seat car that I'm driving as much as possible, as I'm neck deep in a 58 chevy truck project that needs to finish before I tear into the Olds, so I'm collecting parts and trying to plan the attack right now
I should add that I'm going to do EVERYTHING on this car. Frame off, paint, body gaps, shave some from, etc
rapoport05
15
Nov 20, 2025 02:49 PM
Deanjames
Non-Olds Engines
Nov 26, 2016 11:32 AM
lonestarjarhead
Aug 30, 2012 07:04 AM
63 Holidayscottikus
Apr 16, 2012 08:55 PM
bccsrc
Feb 6, 2012 07:05 AM
