1959 Olds front bearings.
Old Sep 27, 2024 | 11:24 AM
OldsViking's Avatar
Hi All,
I am replacing the front bearings on my stock 1959 Olds Delta 88. I ordered a set from Fusick and Rock Auto and they don`t fit. I am 100% sure that the drums have not been changed, since my car is low miles and basically untouched.
The p/n from Fusick is 909066 (Inner) and has a diameter of appr. 75 mm. The drum I have has a slightly smaller diameter, appr. 72 mm.
The outer bearing appears close, but real tight. I ordered them with Rock Auto and p/n is NAT 873.
Has anyone experienced that the socalled stock bearings didn`t fit? And replacement details?
Thanks,
Old Sep 27, 2024 | 05:07 PM
mpolds's Avatar
The numbers are on the old bearings --- along the ledge of the bearing....
The bearings you ordered in both cases are Chineseum... and they are known to be too thin....
I have *** N.O.S. *** U.S.A. made *** Bearings --- that are Always Perfect.......
Always best to simply call me --- 516 - 485 - 193five --- Craig.....
Old Sep 29, 2024 | 10:32 AM
olds-tom1's Avatar
you really should look for quality parts for the bearings; had them from Fusick or Kanter (don´t rembember exactly) for my 48 Oldsmobile model 66 and they fight optical;
had massive problemes to adjust them (too tight or to loose..); gave up, cleaned the old ones, put the correct grease on it and now it is like it is, no play and no noise..
Old Sep 29, 2024 | 02:00 PM
OldsViking's Avatar
My issue is not as much the quality, but trying to find bearings that fit. I am at the process of getting them out and getting the correct dimensions. I will probably call Craig and get NOS if available.
I do find it strange that the drums have different specs than stated as OEM.
Old Sep 30, 2024 | 08:43 AM
mpolds's Avatar
^^^ olds-tm1 , ^^^
If you would like or want *** N.O.S. *** U.S.A. made *** Bearings for the older Oldsmobiles, I have them , too…..
Craig…..
cjmazzeo
Jan 9, 2022 05:42 AM
Del70
Oct 4, 2017 05:37 AM
Supernaut72
Aug 3, 2016 08:14 PM
Jetstar 88
Feb 17, 2012 09:55 AM
Captain_Fish
Drivetrain/Differentials
Oct 3, 2010 12:10 PM
