1957 Oldsmobile 88 Oil Filter Base Drain Plug Gasket
Hey Everyone,
I am experiencing a pretty bad oil leak that is coming from the oil filter base drain plug. The root cause appears to be the gasket (see pic 1).
Per the parts and accessories catalog the drain plug gasket is 5572154 which is most likely an obsolete part number (see pic 2).
At first I thought I can simply make a gasket or use a similar oil pan plug gasket but doesn't appear as the bolt has some sort of hour glass shape to it (see pic 3), also my washer looks crushed and out lived its life span (see pic 4).
The last pic is a shot of the oil filter base where the bolt is screwed into the base. I did call Fusick but they said they have no clue of what I am talking about and said that's not something they sell.
My question, does anyone have any insight of what is a good replacement gasket? Any help would be appreciated. Per the parts and accessories catalog Part number 5572154
Drain plug bolt removed with what appears to be a brass washer. Brass washer that I removed from the drain plug bolt
The gasket looks like its COPPER, not brass. It does show some deformation. I doubt you can remove the gasket without destroying it, but might be possible. You could make a new gasket from a piece of copper sheet.
Try an autoparts store for something from Dorman.
This is what Rockauto shows, which is nylon. https://www.rockauto.com/en/catalog/...ug+gasket,5428
Copper washer/gaskets are available in many sizes. I'm sure you can find one to fit. You can also use a "sealing washer", that's aluminum, with a rubber, or viton insert for difficult to seal applications.
Thanks for clarifying the copper washer not brass.. and yes today I went to the parts store, found some copper crush washers that best fits. The OD was a little bigger and still leaks a little when I turn the engine over... back to the auto part store this weekend. As always appreciate your insight!
Did you run a honing stone or 180 grit sand paper over the seating surface as DFitz suggested ?
Buy a couple of the flat copper washers. They might need to be annealed (softened) to seal well.
Hi There, yes I used 180 as @DFitz suggested but no luck with copper washers. Been to a couple of auto parts stores and they all don't seem to carry the right size where they are a little big for the recessed bolt...
Tried a few copper washers but still leaking, will spend some time hopefully tomorrow and maybe another parts store has the right size. But ya, I'm sure once I find the right size it should square that away.
Have you looked at the bolt to see if there is any scratches or nicks ? The oil can only escape between the head of the bolt and copper washer OR the housing and the copper gasket. Get 2 copper washers. I'll explain later.
Okay so I’m embarrassed to say I been going down the wrong rabbit hole… turns out that the leak is coming from the bottom of the oil filter canister.
It does appear to be sitting correctly in the base. Bummer bc I just replaced the oil, will have to remove and inspect what the issue is, maybe bad oil filter gasket? Anyway happy Father’s Day all
