1957 olds fuel pump
1957 olds fuel pump
Recently bought a 57 Olds with the J2 option. Yesterday while running it for a winter cruise as I was accelerating all of a sudden no response felt like it was out of gas and going to stall out I had just filled the tank. Luckily made it home while letting it idle in the driveway it stalled(never done that) every time I tried to start it would turn over then stall. Car has an electric fuel pump for starts but uses the stock pump afterwards for all I know might be original. Been reading up on symptoms of a bad pump and seems to fit my situation. Before I buy a new/rebuilt pump anyone experience a similar issue.
thanks
paul
thanks
paul
Yep, Mines in the shop as we type for a new(rebuilt) pump. I suspected the old one was on its last legs last summer so I had Fusick rebuild my spare They did the last one about 15 years ago and 45 thousand miles.
If it will not run at all you can put a pressure test the pump or take it apart at the carb and turn it over with the coil wire off but first look to see if any of your filters are dirty, carb, fuel pump and any after market filter you may have added could be that you have gotten a load of water somewhere..... Tedd
Yes mine was one with a glass bowl and on my 55. I think 57 and 58 pump would be the same interchange and work the same both are 371 engines. I'm not sure why one would have a glass bowl and the other not.
I just reread my first post and I left out why you undo the gas line at the carb. If you attach a empty Coke bottle to the gas line and crank the engine over for about 15 seconds you should fill that bottle about 3/4 full if the pump is working, less and the valve on the pump is probably giving it up or about to..... Tedd
thanks again Tedd just to be sure you don’t think there’s any reason why a fuel pump without a bowl won’t work on a car that had a bowl. From what I can see I’m pretty sure mine doesn’t have a bowl and the only one I can get without sending mine first is one without so that’s the one I’m going to order.
Late '57 s and '58s with A/C used a pump without the bowl .
The Hollander says that either type can be interchanged by switching the lines and the fuel strainer .
![](https://cimg9.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/1460x2000/sr_202_gp_3_890_3_904_2e3a6b0e7e685cf440c57ab9b835338fd7f1d77f.jpg)
CholmondeleyWarner
March 20th, 2019 07:42 AM
