1955 Olds not getting gas
Old November 17th, 2020 | 05:05 AM
Bfg's Avatar
Bfg
I have a 55 Olds and is hard starting, I tried to look down the carb to see if there is gas squirting down the carb but very little to none is flowing. I知 gonna first check the rubber hose from the gas tank to the line. I looked at the fuel pump and looks to be difficult to remove. Any tips on removal?
Old November 17th, 2020 | 08:31 AM
Tedd Thompson's Avatar
Does it start right up if you add a shot of gas down the carb? For a test of the fuel pump you can remove the fuel line from the carb put it in a coke bottle and in about 15 seconds of cranking it should pump about 8 ounces of fuel into the bottle.
Two bolts and two gas lines plus the vacuum lines on top of the pump and it should come right out. It's not the easiest place to work but what is on a 65 year old car. The hardest part is the bolt on the left of the pump it's mostly a feel thing if you are working from the top. When replacing it make sure the lever on the pump is riding on the cam lobe correctly. Not hard really just awkward Tedd.
Old November 17th, 2020 | 10:29 AM
Bfg's Avatar
Bfg
Thanks for the reply, I’ll try the gas down the carb first and if that doesn’t work I’ll move to the fuel line removed to see if any gas shoots out at the line. I did see the bolt on the right of the pump but couldn’t see the one on the left. Now that I know there’s one there I’ll check it out. Would I have better access from underneath?
Old November 17th, 2020 | 11:49 AM
redoldsman's Avatar
Proud Viet Nam Veteran
A factory shop manual should show you how to change the fuel pump. If you don't have one you should get one. It is the best money you will ever spend.
Old November 17th, 2020 | 07:27 PM
X2 on what Glenn said. And yes a lift is a wonderful thing..... Tedd
Old November 18th, 2020 | 07:02 AM
Bfg's Avatar
Bfg
I have the service manual next time I get over to where the car is at I’ll check it out. The car has been sitting for a couple of years now ( too many irons in the fire) but the last time it was running it was running poorly, seemed to be starving for gas. I’ll have more time to spend on it now. I’ll keep you posted. I love your 54 and 55’s especially the Liberator! My 55 is a Ninety-Eight 4dr. Sedan.
Old November 22nd, 2020 | 03:20 PM
DFitz's Avatar
74 2.8L Capri
Originally Posted by Bfg
I have the service manual next time I get over to where the car is at I値l check it out. The car has been sitting for a couple of years now ( too many irons in the fire) but the last time it was running it was running poorly, seemed to be starving for gas. I値l have more time to spend on it now. I値l keep you posted. I love your 54 and 55痴 especially the Liberator! My 55 is a Ninety-Eight 4dr. Sedan.
It may be obvious, but remember to check the filter bowl on the bottom of the pump. The original Fuel filter could very easily be clogged. It is a glass bowl on the bottom of the pump, but often there is so much grime on it, you don't know it comes off and there is a paper FF in the bowl. You can't get that FF anymore, so an inline one is easy to retrofit.
While the line is off to the pump, you can also try and blow air back into the line and check for clogs or restrictions that end. When you do, make sure you take the gas cap off.
My car sat for a long time, and the gas had gelled. I had to blow out the fuel line to the tank, even after draining the tank. Worked great after that.
Old November 22nd, 2020 | 04:33 PM
Bfg's Avatar
Bfg
Thanks for that info, I will check it out.
stokerg
January 29th, 2017 12:45 PM
SD72cutlass
December 7th, 2014 04:47 PM
kirkwoodken
September 25th, 2013 10:25 AM
ekamm
October 11th, 2009 12:25 PM
and1stp
November 9th, 2006 03:39 AM
Quick Reply: 1955 Olds not getting gas
