1954 olds super 88 convertible
Old Mar 8, 2021 | 04:32 PM
Eaglefan's Avatar
Thank you for taking this question. Car referenced above housed in Florida. What is the recommended engine oil and transmission fluid for the above for this vehicle?
mark
Old Mar 8, 2021 | 09:02 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Man I would like to see some pictures of your car. There are not many of these around. I run Valvoline VR1 20W50 in my 54. It has the zinc you need for these old flat tappet engines. I tried 10W30 but it seemed to use more oil. That is probably because it is an older engine. As for transmission fluid just run the Dexron/Mercon you get at any parts store.
Old Mar 9, 2021 | 03:51 AM
Eaglefan's Avatar
Send me your personal email and I’ll forward you a picture
Old Mar 9, 2021 | 07:20 AM
Tedd Thompson's Avatar
What Red said. I run Rotella 15 40 in my car mostly for the detergents and zddp in it but any good oil with the correct zddp ill work fine. Same with the transmission fluid anything with Dextron compatible will work fine....Tedd
Old Mar 9, 2021 | 07:58 AM
Eaglefan's Avatar
Thank you Tedd
Old Mar 9, 2021 | 08:34 AM
redoldsman's Avatar
Sent via PM.
Old Mar 17, 2021 | 03:15 PM
ignachuck's Avatar
Frank Ignachuck
This just ain't right. Eaglefan! We all want to see pictures of your car. Let us know if you need help uploading them.
jltexas
Oct 24, 2023 11:26 AM
dzfamily
Jan 6, 2022 08:16 PM
tsgutlass
Sep 23, 2020 07:57 AM
frank58super88cv
Mar 5, 2020 02:38 PM
6duces
Jan 1, 2012 06:34 PM
